T56MaxTorq
Hey guys I have a set of 273 rockers going on my 360 with RHS heads. I have a roller cam that has a lift of .534/.538
Having problems getting the perfect pushrod size. I'm using a checking lifter and adjustable pushrod. I think my rockers ratios are not consistent from one to another. I measure the perfect pushrod size for the exhaust valve (about .526 lift) I then throw the same pushrod on to the intake valve and I read barely .500
I'm going to make sure and double check everything and try different rockers. How far are these things usually out?
