mech pump on a magnum
Hi, there´s a extension snout for the magnum cam, if i remember correctly sold by hughes. You also need the LA front cover.
Michael
Part #7013 from Hughes, its 26.00 bucks, & you'll need an LA timing cover like mentioned.
The 360 cover off of the 88 360 will work, the front is the same, right?
Sweet, thanks guys.
I didn't check Hughes, and couldn't find one !
Sweet, thanks guys.
I would think so on the cover, i could be wrong being an 88, but magnums didn't come out untill 93, so if it has the opening for a mech. pump, then it'll work.
