[WANTED] Mechanical [ REV-LIMITER ]
Cars and Mopar Parts Wanted
Thread Status:
  1. 1Badcolt
    1Badcolt Well-Known Member
    2,322
    1001
    Mar 15, 2013
    Georgia
    Local Time:
    9:26 AM
    Contact Seller
    Greetings - does anyone have a mechanical rev-limiter or limiters packed away that need to be ADOPTED ? Im looking for such - Thank ya Thank-ya Very much .
    • Like Like x 1
    • 694spd
      694spd Well-Known Member
      1,060
      379
      May 2, 2014
      Upstate NY
      Local Time:
      9:26 AM
      Just a FYI,
      I have a cable splitter for a mechanical rev-limiter, if needed.....
      • Like Like x 1
      • 1Badcolt
        2,322
        1001
        Mar 15, 2013
        Georgia
        Local Time:
        9:26 AM
        Very nice yes I will be needing such , I will message you
      • 694spd
        1,060
        379
        May 2, 2014
        Upstate NY
        Local Time:
        9:26 AM
        Here is what using one of the Stewart Warner cable splitters looks like.
        • Like Like x 1
        • 1Badcolt
          2,322
          1001
          Mar 15, 2013
          Georgia
          Local Time:
          9:26 AM
          Nice thank you I should be able to figure that out !! Are new cables still available?
          Thanks Chris
          PS moroso set--up would be identical correct.
        • halifaxhops
          halifaxhops It's going to get stupid around here! FABO Gold Member
          65,811
          35403
          Jan 20, 2014
          Hoppyworld
          Local Time:
          9:26 AM
          I have some cables for the tach to the gauge. Also a nos splitter, no rev limiter and NOS 5" SW cable drive gash mount tachs. No limiter, a few on e bay right now 150 and 250.
        • 1Badcolt
          2,322
          1001
          Mar 15, 2013
          Georgia
          Local Time:
          9:26 AM
          Im eyeing those I will hort up a few
          I need to send u a photo of my gauge maybe u have a mount for it and whatever u have I need we will get that finalized and on the way ok thank you
          Chris
        • halifaxhops
          65,811
          35403
          Jan 20, 2014
          Hoppyworld
          Local Time:
          9:26 AM
          I know I do not have ant "cups" for Gauges.
        • killerslant
          killerslant FABO Gold Member FABO Gold Member
          471
          156
          Jan 3, 2010
          Gobles, Michigan
          Local Time:
          9:26 AM
          Chris, one thing to watch out for if you are actually going to use it is that the majority you see are from HD trucks and have a range if 3500 to 4500 rpm. There is normally a sticker or tag with limit range. You have to look for the old moroso or DC ones if you want the 6 to 7 grand range or higher. 20181204_161801.jpg
          • Like Like x 1
          • 1Badcolt
            2,322
            1001
            Mar 15, 2013
            Georgia
            Local Time:
            9:26 AM
            Ok that helps
            Thanks for info
            I cant buy one or them unless seller can guarantee what specs are
            We can run an msd but u just have to hide it so I have an alternative
          • killerslant
            471
            156
            Jan 3, 2010
            Gobles, Michigan
            Local Time:
            9:26 AM
            That's what I did. Put electronic guts in the tach drive dist and put the msd behind the glove box.
          • 33IMP
            33IMP Well-Known Member
            1,010
            1040
            Jul 3, 2020
            Taxifornia, soon 2b arizona
            Local Time:
            6:26 AM
            I was gonna make a snarky comment about weakass valve springs, but then......
            I have a tachdrive distributor and moroso tach, and never knew such a thing existed! Learn sumpin new every day!
          • 694spd
            1,060
            379
            May 2, 2014
            Upstate NY
            Local Time:
            9:26 AM
          • 1Badcolt
            2,322
            1001
            Mar 15, 2013
            Georgia
            Local Time:
            9:26 AM
            Good ole [ US ] technology
          • 1Badcolt
            2,322
            1001
            Mar 15, 2013
            Georgia
            Local Time:
            9:26 AM
          Thread Status:
