bwhitejr
Edelbrock Performer RPM heads require mechanical rocker assemblies when you use have larger than stock cam. Can someone tell me how to set up the rocker arm assemblies to work with hydraulic lifters. The mechanical pushrods I bought are just under 7 1/4" long. Are these the correct ones for my application? Some say preload, Mopar says no pre-load??????????
bwhitejr
bwhitejr
