Mechanical temp sender fitting
HPP
Most aftermarket mechanical temp sending units have the temp probe that is a good 3" long. The problem with that is most aftermarket intakes don't have this much depth in the temp mounting hole. What are some solutions you guys have used to accommodate aftermarket temp probs?
Rolled one of these in the upper hose
