Map63Vette
So I hope to have all the pieces to my fuel injection puzzle coming together in the next week or two and I got to thinking that there's no reason I couldn't get all the wiring done ahead of time while I'm waiting on parts to be delivered. I know that the Megasquirt main computer at least needs to be in the interior for weather protection, and I don't really feel like cutting a big hole in the firewall to pass the 37 pin connector between it and the relay board, so I plan to mount both inside. I took a look under the dash and there's really not much for flat surfaces to work with, so I was wondering what other people had done for computer mounting options. I thought about putting the relay board near the passenger kick panel (just above it or maybe behind it) and the computer in the glove box, but I wasn't sold on the idea. I thought about making a mounting bracket that hangs off the bottom of the dash and doing it that way, but then I figured surely someone out there has already mounted a system, so has anyone got pictures of their computer setup? I would like to keep fairly easy access to the relay board at least so I can replace fuses and relays if needed, and easy access to the computer for programming would be nice, but I can always just leave a cable attached and tuck it out of sight when not in use.
