Has anyone had any experience with the melling MLP-201 engine priming system. Specifically on the 340/360 LA engine.
I have used that and find it to be difficult at best, but that’s probably because have not figured out the trick behind getting the gear out and back in correctly without a lot of swearing. Has anyone considered making a quick video about the “tricks” involved? I know it’s supposed to be simple.No. I use one of these.
CHRYSLER Summit Racing SUM-901013 Summit Racing® Oil Pump Primers | Summit Racing
Good point on the Allen tool possibly fouling the bushing. I wrapped some masking tape around the Allen, but any tape or even a piece of shrink wrap or thin wall hose would workYou want to be careful. A long allen can beat up the bushing. There is no trick to getting the intermediate shaft out. Take a large screwdriver and turn it. I never remember which way. One direction will walk it right out of there. You can prime the system by tapping some sort of pressure fed oil into the sender port, but that does not prime the pump, necessarily
Turn it CCW.You want to be careful. A long allen can beat up the bushing. There is no trick to getting the intermediate shaft out. Take a large screwdriver and turn it. I never remember which way. One direction will walk it right out of there. You can prime the system by tapping some sort of pressure fed oil into the sender port, but that does not prime the pump, necessarily
Fur sure !!Twist the gear while lifting it out. You prime the engine though, before you ever install the gear.
