[FOR SALE] Metric Dial Indicator 0-10mm
'63GT
CA
Jeweled Czechoslovakian movement. Somet CBN 251811 0-10mm (travels 11mm)
1 increment is .0004 inch, and 5 increments is .002 inch, 10 increments is .004 inch.
Silky smooth! Never used, like brand new. There is no lug on the back, intended to be used with a clamping fixture on the stem. In original case.
$50 + $8 shipping
Jeweled Czechoslovakian movement. Somet CBN 251811 0-10 mm
$50 + $8 shipping
Is the shaft threaded to accept extensions at the bottom and if so are there any extensions that come with it ?
thank you for your interest !
Yes, No. The anvil on the end is knurled, so that it could be removed. This one is ball point.(see new pic downloaded - you can also see the back and the anvil)
Apparently, these indicators were shipped with, or without, additional anvils. (3) I don't have the anvils, so they were either lost before I got it, or they weren't supplied.
You can get anvil kit's on Ebay for $8 but I don't know if they're available in metric thread. this indicator most likely is.
22 PC Dial Digital Indicator Point Set | eBay
