Mopar-Man
Big Block Better Burnout
I was told my 440 heads were angle milled. I don't know how much. I assumed the intake was as well. Now I am not so sure. I look down the ports with a Maglite and I can see about .030" of the tops of each cylinder head port. In other words, the intake looks to be sitting HIGH on the heads. My buddy loaned my an M-1 that he KNOWS is milled and I set that on the motor. Now I can see .030 of the BOTTOM of the cylinder head ports!
Both intakes are on a stock bathtub gasket only.
Should I just ditch the bathtub and run fiber gaskets with the M-1 then it will line up? Have you guys ran across this before?
