Milling Pistons ?
flipper
Canada
Would anyone know how much I would need to cut off the domes of a set of TRW 2322 pistons to bring my comp. down to 10.0 to 1 with 64.5 cc chamber heads ? And with a comp roller with .544 lift would I need to recut valve reliefs ? Thought someone would know .
Dont know if you can still find the dome volume on those old pistons.....
but with a 64.5 cc head....pretty much got to make them flat tops ..since a stock 340 flattop is near 10 to 1 at that head cc..
maybe im wrong but I think a 10 to 1 340 piston is 0.20 above the deck .
jimjimjimmy I was at Oyster Bed Bridge on Tuesday night couldn't hook at all , spun every run .
that is what you have to do....1/2 inch fill on the cylinder so you can cal the dome volume...
but as said above...a 68-71 340 piston is usually out of the deck anywhere from .008 to .020 ...and adjust the head gasket accordingly and you will have a 10 to 1 compression..
I got a set that had the dome milled mostly off...but they are in a old 340 in the corner of shed...you can just make out the dimple for the spark plugs still...
The dome volume on those is -10.7 CC's.
So without doing a mock up could I use the pin center line and just mill the same height as a set of 10 to 1's ?
Crapped if I know. You got the numbers. Do the math.
I believe I have a plan thanks .
Are you sure you want to 'slice' the top of those Baby's off.
The TRW L2322 Pistons are a bit heavy, but they are indestructible.
Maybe a 'trade'.......
[URL="http://www.forabodiesonly.com/mopar/data:image/jpeg;base64,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"][/URL]
Do you have .060 10:1 comp pistons ? I can get them machined for about 15 dollars apiece .
Are these those 'Sweet' Kardashian's that you have.
attachment.php
figure out how much clearance volume that you need.
CC your heads.
Measure your gasket.
Put one of your pistons in and put it at TDC and see where the dome is.
Now calculate how much volume that you need above the piston and how much you need to adjust it.
Now measure your piston compression height and then calculate where it needs to be to get where you want to go.....
