This is for anyone that has Milodon 30940 pan and the corresponding dipstick 22060 that don't want to run the pan to full oil capacity and find that the dipstick is a bit short, for around a dollar you can fix it without to much drama, you'll need a length of 3/32 or 2.4mm stainless steel tig filler rod, heat and remove the old wire then replace with your new cut to your length wire.
