mini tub help!!!
Ptdartfreak
Mopar freak
CA (unfortunatly)
the previous owner did a mini tub from hell. he never filled the stip so i figured i would take the tub out and do it right.
Well the tubs are pretty well destroyed. (from the previous owner not me taking it out)
is there a wheel tub that i could purchase and install but keep my rear seat?
please tell me how i go about this.
thanks
chad
Is the INNER FENDER well messed up? I think you could make one yourself to keep the back seat in tack. The edges would be squared but you could do it for sure!
I have some wheel houses, not free, but I have them
AMD makes an inner wheelhouse and they are 130 or so for each side.
Chad,I,d get the wheel houses from Crackedback,then you can make your own strips and do the job properly.Good luck with getting the seat in.:read2:
What I usually do is take the factory wheelhouse out, split it down the seem in the middle add in how ever much you need then weld it back in and you can recess the part where the seat goes in to keep from having to modify it. Wish I had a picture to show you, sorry! If I do it to my dart sport I will post pics but still not sure if I'm going to.
Here are a couple picts. The rest are on my resto 73 duster oregon.
