Yea the only beads I was running was on the filler pieces and the top and trunk brackets. Those tubs have to be really stout because the top brackets that weld to the tubs have the spring that has holds tension on the top and all that leverage is on the tubs. Didn't effect the top function so that's a relief
Looking good, just a little tip, you do not have to weld everything solid, just some evenly spaced spotwelds will do the trick, that's how the factory did it......
