[FOR SALE] Miscellaneous exterior & interior parts
Yote
far eastern Colorado
Miscellaneous interior & exterior stuff, most, but not all, are from my ‘72 Demon 4/speed, project. Price does NOT include shipping from 80758. If I am offering anything that you think should be trashed, let me know.
USPS Money order, I don’t do PayPal. PM me if needed, to get individual photos of anything you are interested in. Yote
$20. -Speedo gear —- 37 tooth - used but looks good.
$20. -Speedo housing- - used, some deterioration on threads, but still usable.
$10. for all —Wiper arms—— used,- 3-14” — 1- 17”
$15. -Hub covers——Chrome,New in box. For wheel center opening of 2.95 “
$.50 -Washer resivoir cap
$1.50. -Steering column spacer- used
$10. —Under hood Wiring harness -horn,headlights,front side marker. One tab
broken on bulkhead connection & scotch lock scuff on insulation.
$1. ea. -Fuel sender lock rings- 2- new— not original
$2.50 Spark plug wire clips-2.
$35. -Radio speaker - new , 4x10” , 4 ohm. Bought set of two only needed one.
$3. - Speaker 4”- 4 ohm /2 w
$5. - Dash bulb sockets- 4, with bulbs
$25. -Throttle pedal - cleaned/painted with 24” cable.
$7.50 - Battery tray -cleaned, repaired hole, painted with support brace.
$7.50 - Kick panel-black, passenger side.
$5. pair -$7.50 for all 4-Headlight retainer rings.- chrome ,2 like new,
2 -mismatched
$15.- Tie rods - pair- still tight but need new rubber boots.
$10. - Idler arm- seems tight
Only reason tie rod/idler was replaced was that they were included
in complete suspension kit.
$7.50 - 2 head light buckets , mismatched but taken off off of ‘72 Demon
$50. —Exhaust manifold-- casting number 2951916 with heat stove. Not sure
what it fits, that is up to you.
$150. Tail light - for Demon, passenger side, chips repaired, lens polished. With housing, cleaned /painted. With used gaskets still serviceable.
Pm sent on the 68 up idler arm.
headlight retainers all 4
Toerods
Kick panel
