Misfire - Ignition Advice
Electrical and Ignition
  1. Pana.Mopar
    Pana.Mopar Duster Down Under
    311
    31
    Apr 25, 2008
    Sydney, Australia
    Local Time:
    10:02 AM
    Hi All, Hope everyone is staying safe.
    Just want to ask advice with misfire/ignition on my 383. It's misfiring slightly above 2000rpm and damn annoying. It has stock Mopar electronic dizzy and MSD Streefire Ignition module. Have change plugs, leads and still hasnt fixed it. Any ideas on where I should look into it?
  2. Bewy
    Bewy Well-Known Member
    1,499
    958
    Jan 1, 2021
    Australia
    Local Time:
    3:02 AM
    Pana,
    I am in Sydney. PM me a ph # & I will give you a ring.
    • Like Like x 2
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      52,374
      21510
      Oct 14, 2010
      Idaho
      Local Time:
      8:02 AM
      Describe more about the problem. Is this at any throttle, or not there under light cruise but there under heavy throttle, etc?
      Did this pop up all by itself and had been running well, or did you change something and "now it's there?"
    • Pana.Mopar
      311
      31
      Apr 25, 2008
      Sydney, Australia
      Local Time:
      10:02 AM
      It's been there for ages. Its usually once the car is hot and above 1,500rpm on the throttle. Doesn't do it at low speed or cruise.
    • Early a body
      Early a body Well-Known Member
      197
      90
      Jun 25, 2018
      Nevada
      Local Time:
      8:02 AM
      I would need to know what carb you are running. What is your ignition timing at idle at all in?.
      i would check the reluctor in the distributor, I had a similar problem a few years ago on a older mp distributor, turns out the reluctor in the distributor looked like a mouse was chewing on it so where it passes the pick up it was not straight any more it was literally all chewed up. Once I replace the reluctor problem solved.
      But your carb jetting/ adjusting and what timing you are at make a difference too if the reluctor is in good shape. Is the carb sitting on the intake or is there a spacer etc.
    • 67Dart273
      52,374
      21510
      Oct 14, 2010
      Idaho
      Local Time:
      8:02 AM
      So you are saying that heavier throttle causes it? I would suspect low spark voltage. Bad coil wire, bad coil, something wrong in the ignition module, or LOW 12V SUPPLY VOLTAGE to the unit, caused by a number of things, including mis-wired (are you using a ballast and is it supposed to?) or other harness problems
      Try separating the ignition system from the harness and 'hot wire' it direct and see if that makes a difference
      • Like Like x 1
      • Righty Tighty
        Righty Tighty FABO Gold Member FABO Gold Member
        1,433
        1356
        Aug 16, 2019
        Sahuarita, AZ
        Local Time:
        9:02 AM
        Would using an incorrect ballast resistor (4-prong instead of 2-prong) cause this?
      • 67Dart273
        52,374
        21510
        Oct 14, 2010
        Idaho
        Local Time:
        8:02 AM
        Sure
      • bee1971
        bee1971 Active Member
        43
        23
        Aug 23, 2009
        Sobieski WI
        Local Time:
        10:02 AM
        Wouldn’t a MSD Streetfire Module require full 12v directly from the Battery
        And then the coil + is directly fed off the MSD Module
        Why would anyone run a Ballast Resistor with that system , when it should bee completely eliminated within the wiring schematic
      • Righty Tighty
        1,433
        1356
        Aug 16, 2019
        Sahuarita, AZ
        Local Time:
        9:02 AM
        I was more asking for my own knowledge as opposed to troubleshooting this particular situation, sorry.
        • Like Like x 1
        • Pana.Mopar
          311
          31
          Apr 25, 2008
          Sydney, Australia
          Local Time:
          10:02 AM
          I'm running Quickfuel 750 Double Pumper on it. Ignition timing is at 14 (I think?) Yeah I've got an old MP distributor on it.
        • Pana.Mopar
          311
          31
          Apr 25, 2008
          Sydney, Australia
          Local Time:
          10:02 AM
          Correct, there's no Ballast Resistor on this.
        • Pana.Mopar
          311
          31
          Apr 25, 2008
          Sydney, Australia
          Local Time:
          10:02 AM
          Yeah, when the car is hot it happens thru the mid rev range. Also noticed that when I jump on the throttle ant high revs it wants to die (sounds like a fuel issue)
          Have changed all the leads on it. MSD Blaster Coil is near new. There's no ballast resistor on this set up.
        • fishmens67
          fishmens67 FABO Gold Member FABO Gold Member
          11,299
          11215
          Nov 10, 2012
          idaho
          Local Time:
          10:02 AM
          sounds like you're running the factory Mopar performance curve . are you hooked to vacuum advance?
        • Pana.Mopar
          311
          31
          Apr 25, 2008
          Sydney, Australia
          Local Time:
          10:02 AM
          Nah, vacuum advance is blocked off.
        • fishmens67
          11,299
          11215
          Nov 10, 2012
          idaho
          Local Time:
          10:02 AM
          If I remember your combo right you should be running initial timing of at least 20 probably 22-24 with 36-38 total.
          I'd start there and retune the carburetor and check fuel flow when it's hot.
        • Pana.Mopar
          311
          31
          Apr 25, 2008
          Sydney, Australia
          Local Time:
          10:02 AM
          Yeah, I think I'll go back and do timing and carby and see how it goes.
        • bee1971
          43
          23
          Aug 23, 2009
          Sobieski WI
          Local Time:
          10:02 AM
          Old Mopar Distributor
          Bushings
          Distributor cap/rotor
          Rotor Phasing
          Did you check the gap on your reluctor / pickup coil ? .008 with a brass feeler gauge
          Check it at all eight points on the reluctor , see if the pickup coil is hitting the reluctor while spinning
          Could bee the pickup coil itself failing also when hot
          If you think it’s the MSD Streetfire Ignition Module failing , how hard would it be to reinstall the Mopar/Chrysler ECU or Ignition Module on the firewall , or even a points distributor
        • Pana.Mopar
          311
          31
          Apr 25, 2008
          Sydney, Australia
          Local Time:
          10:02 AM
          Thanks mate. Will check these things. I've left all the original electronic wiring there so wouldnt be hard to put a new dizzy and original dstyle ECU back in.
