Modern Disc Brake Conversions?
Cowboy
Surprisingly Not Banned
Anywhere
Has anybody tried swapping any type of common newer spindles and disc brakes on to a factory A body suspension setup? I did a search on the site and came up empty handed.
I was thinking about looking into using 90's-00'ish 2wd S-10 or Dakota parts? All the hoarders in the area won't let anything original go for anything under a fortune.
Any input would be appreciated.
Sounds like you found a suitable donor for parts. To answer your original question: Yes, kinda. This what you describe is similar to the Scarebird disc brake upgrade kits.
