[WANTED] molding fasteners
Dne007
Cypress, Tx
I know this is going to be a tough one. There's a chrome molding which goes around the back glass and down to the tail lights. There are 8 fasteners/retainers along the roof line which I need. Along the trunk are just weird wire nut things which I can find online. I was going to fill the holes and go chromeless, Now I think I'd like to re-install when it comes time. So, I'm looking for the 8 plastic retainers:( The pic of the nice car is not mine, it's just to show the chrome molding.
dne'
I had a similar experience with a 69 Dodge D200 I owned & could not find the proper trim clips I needed for it anywhere. I ended up buying two-sided tape & using that to install the side moldings. It worked like a charm & lasted a long time too. If you can't find the ones you need, try it.
They're kind of a plastic clip~ the big part pushes in expanding the prongs. This is close, but doesn't fit:(
