Here are some pictures of a Molnar crank on a balancer and the weight removed from the outer diameter. also the print of the 8 spins after cuts. It will get more cuts to get it closer. Check the videos in the next post.
Also I posted pictures of a molnar and a scat here with motors built elsewhere. Check out the holes they drilled. One of the holes with the flashlight in shows the drill hit one another. One crank is from Jensen machine. Can you say vibration
Then look how he reduced the holes and depth by cutting the diameter in the next post videos of the computer graph. When he is done there will be barely any hole drilled. Torque out the gazoo with way less outer reciprocating weight. The last picture is the crank for our small block
