[SOLD] Moog Front End Kit for 1966 Dart
66DartConvert
Member
PA
FOR SALE:
Moog Front End Kit for 1966 Dart. I sold my Dart so no longer need the parts. This kit will likely to fit other A-body years/models as well, but please check the part numbers provided below before purchasing. Note: The lower ball joints in this kit are for drum brakes. The lower ball joints are a different part if you have disc brakes.
Kit Includes (Moog part numbers and quantity provided below in parenthesis):
- left and right upper ball joints (two K704)
- left and right lower ball joints (one K785 and one K787)
- left and right inner and outer tie rods (two ES319L and two ES319R)
- one tie rod adjusting sleeve (one ES319S)
This kit is identical to this $600 kit available from Moog (Note: You have to select the lower ball joint type on the moog page to get full kit price. The price they show at first, 400, does not include the lower ball joints)...
Front End Steering Rebuild Kit | Dodge Dart 1963-1969
BUT...the moog kit has TWO tie rod sleeves, and I have ONE. The Moog cost for another sleeve, if you need it, is $21 bucks (Tie Rod End Adjusting Sleeve | Dodge Charger 66-72)
Moog parts are high-quality which is why I went with them.
Asking $275 or best offer!
Thanks for looking!
