74Dusted
Stock Piler of 340's
Just finished installing a new vinyl top and replaced the moonroof assembly in my '73 Duster. The gears & cables were chewed up in the original. The "new" moonroof has perfect cables & gears in in it
The "new" moonroof was completely dismantled, cleaned, lubed, put back together and installed in the car. It cranks pretty easy, forward and back, but when it gets to the closed position, the back doesn't seem to want to lift unless you give it some assistance (by hand)
What's going on there?
