[SOLD] Mopar A body 4 speed
jtkaaa07
BossMan
Neenah Wisconsin
Rebuilt A body 4 speed correct for any A body ,Dart, Duster, Barracuda, Demon etc from 64-76. This is a standard 4 speed, NOT the overdrive version! Has the 4.35 bearing retainer on input shaft. Has the 26 spline output shaft . Freshly rebuilt transmission was completely disassembled cleaned and inspected, with all new bearings synchronizer rings, slider keys and springs, and seals. This is not a spray can rebuild and is in absolutely excellent condition, and ready to install! Asking $750 plus the ride, which is normally around $130-150 anywhere in the continental U.S.A.. Located in Central Wisconsin
where did you get that yellow plug for the rear seal? i am guessing that will retain the fluid during clutch swaps? thanks for the info
