Mopar CFM Ratings for Carburetors
69 Cuda 440
Legandary Member
Legendary Member
Wilton, Connecticut
Mopar 'Hustle Stuff' Catalog {Mopar CFM Ratings}
Carter AFB
#3853S ............. 460 CFM ...... 1965 '273/235 HP ' ~ {Manual Transmission}
#3249S ............. 450 CFM ...... 1962 '361/305 HP'
#3447S ............. 570 CFM ...... 1962 '413' {410 and 420 HP}, and 1963 '426' {415 and 425 HP} 'Max Wedge'
#3258S ............. 465 CFM ...... 1962 '383/343 HP' ~ {Front Carburetor}
#3259S ............. 475 CFM ...... 1962 '383/343 HP' ~ {Rear Carburetor}
#4742S ............. 570 CFM ...... 1970 '426 Hemi' ~ {Front Carburetor ~ Manual and Automatic Transmission}
#4745S ............. 570 CFM ...... 1970 '426 Hemi' ~ {Rear Carburetor ~ Manual Transmission}
#4746S ............. 570 CFM ...... 1970 '426 Hemi' ~ {Rear Carburetor ~ Automatic Transmission}
Thermoquad
#4972 ............... 800 CFM ..... 1971 '340' ~ {Manual Transmission}
#4973 ............... 800 CFM ..... 1971 '340' ~ {Automatic Transmission}
How about the 360, 400, 318, and 273 2bbls?
2-Barrels
273 ~ {1964 thru 1969}
Carter BBD {1.437" Throttle Plates x 1.063" Venturi}.......... 275 CFM Rating
318 ~ {1968 and up}
Carter BBD {1.437" Throttle Plates x 1.186 Venturi}............ 285 CFM Rating
360 ~ {1971}
Holley {1.563" Throttle Plates x 1.343 Venturi}................... 350 CFM Rating
383 ~ {1962 thru 1971}
Carter BBD {1.563" Throttle Plates x 1.313" Venturi}.......... 365 CFM Rating
400 ~ {1972}
Carter BBD {1.563" Throttle Plates x 1.313" Venturi}......... 365 CFM Rating
What do you have on the 1968-70 340?
I know these could really wake up with a bigger carb.
Back in the day, I installed a 1973 T-quad & intake on my 69 340 Dart & picked
up 4 tenths.
up 4 tenths.
Mike,
340/275 HP {1968 thru 1970}
* Carter AVS
* Throttle Plates.... {1.437" Primary x 1.686" Secondary}
* Venturi ..............{1.186" Primary x AV Secondary}
* Primary Jets ...... {.089"}
* Secondary Jets .. {.095"}
* CFM Rating......... '630'
Note; This is 'directly' from the Carter Carburetor Specification Book {old schoolbook}.
What about the one year only Rochester 2GV on my 71 318 Dart?
Big Tom,
How can that be ?
Rochester #2GC Specifications
Rating_______Throttle Plate x Venturi
* 278 CFM ............. 1.437" x 1.093"
* 352 CFM ............. 1.686" x 1.186"
* 381 CFM ............. 1.686" x 1.250"
* 423 CFM.............. 1.686" x 1.312"
* 435 CFM ............. 1.686" x 1.375"
Carter CFM Ratings
As per the Carter Catalog
AFB Carburetor for the 273
1965 .... #3853 and #3854
1966 .... #4119 and #4120
1967 .... #4294 and #4295
Primary ......... 1.437" {Venturi > 1.063"}
Secondary ..... 1.563" {Venturi > 1.250"}
As per Chrysler, this Carburetor was 'advertised' at 500 CFM.
But, the Hustle Stuff Catalog listed it at 460 CFM.
Our testing back in the day, had the best one performing
at 517 CFM {W.O.T.} with some 'tweaking'.
