MoparAnglia
Just pulling my little 318 apart for the stroker combo, but discovered some surprising stuff. The forged pistons I knew about, but it turns out I have 360 pressed pin rods (2532922) on what looks like a 2858383 crank - that's not a recognised casting no. so I may have misread that.
I've discovered its been balanced at some stage too but don't know if internal or external? The (presumably factory) damper has no extra weight or a big groove in the outer ring but it does have four large 'dimples' in the front face of the outer ring. Anyone know what its off?
I'd quite like to pass the rotating assembly on with as much info as I can provide.
Cheers
Jamie
Cheers
Jamie
