[FOR SALE] Mopar Door Hinge Remanufacturing Service
I know your post says 67-78 A-Bodies but would you happen to Offer this service for early A’s? I have a 65 Valiant that has really bad door hinges. They are already off the car and in a box.
Hi Leo,
Can you fix 1965 Barracuda door hinges? I have an upper and a lower left door hinge off the car that are lnicely painted but somewhat lloose. What would your price be to fix them?
Also, would you want to buy them as is for your inventory?
To the OP: if you need early A cores I have a ton of them of which most are actually tight.
I read that the 63 to 76 A body hinges interchange if you don't mind not keeping the "original" hinges. I don't know what MoparLeo would charge w/o the newer cores.
All 63-76 door hinges interchange, and are the same from left to right (one side is upside down from the other.
Beware of hinges repaired by welding. . The new metal is harder than the surrounding metal and will wear on the hinge pin pretty quickly if you don't keep them well lubed
