[SOLD] Mopar Garage sale
Sedanman
67-9 Valiant specialist
chicago Il
67-76 a body manual disc brake rod & bolt $25
67 273 engine block,cam, heads,pistons & rods $150
A nice pair of bumpers with bumperettes for 67-73 valiants & 70-2 dusters $200
I have a nice complete set of chrome upper door panel trim for 67-9 2 dr sedan valiants & darts. It is the piece that the door panel slides into. $40
I have a box full of side trim for 67-9 dart & valiant 2 dr sedans. It is the chrome that goes on the doors,post & rear 1/4 windows. I'll take $200 for all of it
70-up Small block alt brackets with bolts,spacers & matching pulley's for power steering & non A/C $75
2 sets of 67 valiant grills,1 set of bezels & 1 grill emblem $150 obo for all
67-74 duster/valiant gauge cluster computer board with no broken pins $20
2 67-9 valiant 100 emblems with good tabs $20
67 valiant owners manual with sleeve original $20
a body chrome brake pedal pad $20
Misc fender mounted antenna nuts & bezels (offer)
Telescoping antenna mast (screw in) $40 obo
RH fender mounted t sign housing $10
8 3/4 small joint,coarse spline yoke with bolts & straps $50
manual brake push rod,bolt & rubber $30
throttle return brackets $10 ea
wiper motors $20 ea
I have a pair of 3" Warlock mufflers with cutouts,never been used. They are $90 ea new. Make an offer
11" 8 3/4 backing plates. I can't remember if 2" or 2.5 wide shoes $40
Kframe to rad support bracket with bolts $10
factory rear exhaust hanger,weld on type $10
small block oil dip sticks & tubes,long ones are truck & other is car $20ea
68 valiant guage cluster,speedo works $40
67-9 black visors,1 has had the seam come loose but in nice shape if you can sew $20
68 valiant pass fender used but has NOS # visable $175
Shipping is not included
more pics
more pics
It was from a 90's police car my buddy had stripped. It looks like it will fit in a dash where someone cut the radio area out for a new style radio. Yes they work. Thanks
They are mechanical & $40 shipped
The temp guage has 1 wire for the sensor,the oil uses the tubing
Pics?
I am taking most everything to the Nat's next weekend that doesn't sell by Wed and can deliver parts you want prepaid and will hold them at my spot
