Calcrenshaw
Member
So I though I had a ballast resistor problem. Test the resistor on one pole it was good. Other was open. This is a 74 dart . Replace resistor still no spark. Bought a "4" pin cheap azz control module and what do you know bam it runs great ! So can an icm cause a ballast resistor to fail?
