Mopar LA valve cover ??s
djwhog
OK I purchased a set of these Mopar valve covers. I like the easy to clean metal chrome. But they only have open holes. I think they are 1.25" ? Anybody running these, and what did you do for the gromets for the PCV and Breather. I am sure they need to be push in type. I read there are some gromets that are baffles built in. I wopuld guess the breather will get pulled out to put oil in ...
The pictures show them with gromets, but none come with them. I checked from several sites and none in the boxes.
DCC-5007446
Any help please thanks!
:salute:
They can be ordered from MoPar or Mancini racing. There no longer included with the valve covers. Order them seperatly as a package, like a stock engine would have or 1 breather and a PCV, 2 breathers etc.......
Did you order the type from them that are supported with baffles? I hate to see any oil come up from any crankcase pressure. I thnk some covers have baffles built into them so the oil stays off of the gromets, pcv breather etc.
thanks!
I grabed the black wrinkle covers. I had to order the breathers and baffles seperatly.
(Bastards.) The baffles come with 2 plates and at least 6 screw that self tap into the cast in stands the baffles sit on.
Yep seems like every chance they get everything is extra. Soon we will pay for air n the tires... oh yeah some places already do that huh.. :blah5:
I had different covers, however the hole dia are the same. A K&N filter itself works great without the use of a gromet and is what I use as the oil filler as well. It would have to be used over a baffle plate. As per PVC, a gromet from a dealer with a 3/4 hole for the valve.
