mopar msd 6al box
Muscley MOPAR
hull iowa
so I was a checking compression on my motor nd I had my valve covers off nd my plug wires off too nd forgot to unplug my msd and Wen I got everything back together nd tried starting it nd I had no spark...pre sure I fried my box by cranking it over first is that what happened and second does anyone no if I could take it apart md solder or fix it
Test it dude.
[ame]http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Products/Ignitions/6420_instructions.pdf[/ame]
Page 9-10
i did test it the way msd tells you to by shortin the mag. pickup wires and i got nothing i checked both 12v wires and they were good and my coil is good as well i double checked that...i called MSD today and they said that cranking it when all the wire are off shouldnt affect it but thats when i got issues right after that...also i was planning on sending it away but its a mopar performance msd unit part number 4876728 black box
