[SOLD] Mopar Performance 360 Cast 4.0" Stroker Crank – Used
Rocket
CT
I have a nice used Mopar HD 4.0 stroke, 360 main, cast crankshaft part number P5007258. Crankshaft is in nice used shape and was new when installed in a bracket car. Journals are standard dimensions. Some deburring was performed on the throws and other areas as you can see in some of the photos. This crankshaft was used for two seasons and have gone another direction. Crank shows some typical marking for being used. Most marks are not able to be felt with a fingernail. A couple you can slightly feel it.
Price is $275 plus shipping.
Yes it will. Here is the description from Mopar
“These heavy-duty surface hardened, Cast Crankshafts feature radiused fillets at main and rod journals. Requires balancing. 6-bolt pattern on crank flange.
4.00" Stroke (360 Small Block Main, 5.9L Truck Magnum/ Jeep Engines)”
I used Eagle H Beam connecting rods part number CRS6123C3D (for sale separately) and Keith Black 4.030 flattop pistons part number KB744 and a Summit Racing damper part # SUM-B64278. I still have the damper and can sell with the crankshaft if it is of interest.
Summit Racing® Competition Harmonic Dampers SUM-B64278
View attachment 1715308720 View attachment 1715308721 View attachment 1715308724
Good morning rocket, i might be interested in the damper how much do you want for it ?
Gary
PM sent. I do not have the pistons. KB 744 pistons were used - pictures above.
External balance is how I used it. It used a B&M external balances flex plate.
