For sale is a new Mopar Performance hydraulic cam and lifter package. Part # is P4529963. Specifications with 1.5 rocker arm ratio are 0.521 lift intake and exhaust and 296 degrees advertised duration intake and exhaust. Valve overlap is 80 degrees.
Description in the Mopar Performance catalogue is Factory engineered hydraulic cam and tappet package for the ½ mile flat track 318-340-355-360 applications, 296-296-80 degrees, valve lift .521 intake and exhaust, centerline 108 degrees, install at 106 degrees intake. Lifters are sealed in original boxes. Camshaft is sprayed with oil to prevent surface rust so you will see a little attracted dust on the cam in close-ups.
Friend had the same cam and lifter kit in his small block Duster. Great midrange and higher RPM power. Needs a good gear and stall converter for a strip street or bracket car.
Price is $160 shipped in the lower 48 states. I will also ship internationally for the additional shipping cost.
