Cal Tonsley
Just wondering what the maximum lower (above the hex) shaft diameter is meant to be on the Mopar Performance P3690715 oil pump drive shaft? The new one I have measures .449” versus .407” for the original / std 360 shaft. The std one spins perfectly in the block but the MP one binds and is hard to turn. Just in case you’re wondering, the issue is where it passes through the block below the bronze bush (I have reamed this and both shafts are exactly the same size there and turn nicely through the bronze bush) At the moment I can only run the std shaft due to binding but would be happy to turn the MP shaft down to a smaller diameter so a target size would be helpful. Thanks in advance.
