76 440 in my D100. I had to clearance the cover on the RH side and the LH was ok. Here is the problem. While trying to figure out what the RH interference was, I reversed the covers. Meaning the PCV is now on the front RH and the breather is on the LH front. Any issues?
No I can’t swap sides or I’ll have big ugly grinding marks showing. Both have baffles and this is front sump oil pan if matters. Stock had PCV LH rear and breather RH rear. Craig
