[SOLD] MOPAR Race & Street Parts:
DART5770
Albert Lea, MN
MOPAR Race & Street Performance Parts:
*NEW Hoosier 28-4.50x 15 drag race front tires. (2) (reg $155 each). $250 for the pair!
*SB Mopar cast iron Econo W-2 heads with Mopar valves, 2.02" & 1.60". No springs or retainers. Casting #3870810. Have been hot tanked and mag'd. Has bronze-wall guides (spiral type) Only minor bowl blending. Little use since
brand new. ****$800 *** Have springs and retainers available to complete.
*Holley Strip Dominator. SB Mopar W-2 head oval port intake manifold. $175
*Holley Street Dominator. SB Mopar W-2 head oval port intake manifold. $165
*NEW Holley Strip Dominator SB Mopar W-2 head, SQUARE Port intake Manifold. Also fits Indy 360-1 Heads. Never bolted on an engine. ****CALL****
*TCI Street_Fighter shifter 727-904 torqueflite. Forward or Reverse pattern. $100
*GIBSON STAINLESS STEEL headers for Dodge Ram, Dakota, or Durango 1996-2003 with 318 or 360 engine. 2wd or 4wd. Excellent condition.
The elite in late model headers, part#301-S. Thick 3/8" flanges, rust through prevention from stainless steel. Fits stock Y-pipe. Shorty design.
Headers have been glass beaded and painted. Headers sell new for $525!! A steal at $250 for the pair.
*Pair BB Mopar '346' head castings with OE stock valves. Same as '906' or '452' heads. Milled approx .080" - 78cc chambers. Approximately 10 cc's smaller than stock and comparable to 915 closed chamber heads. Fresh, but older valve job. Could use 2 seats. AS-IS $250 OR with ALL NEW
Bronze guides, 2 seats installed and fresh multi-angle valve job and springs, retainers, & positive seals completely assembled with tip height and
spring installed height set. *****$695.
*Pair of STRANGE ENGINEERING 35 spline Pro Race axles for B-Body, 8-3/4" or Dana 60. Comes with
1/2" x 3" long studs and 'Green' ball bearings. Came from low horsepower car, splines are perfect! NICE!! $325 Over $500 new.
*NEW TRW L2316F-20 forged piston set with pins for 340 Mopar +.020".(missing tru-archs.) Flat top 10.25 comp. $325.
*Milodon deep pan and pickup for 360 or Magnum engines - cars. #30940 & 18345. 8 qt. 8-3/4" deep.
Some modifications. $185
*Factory 426 Hemi rods, used, singles. $50 each.
*426 Hemi race pistons, singles, Venolia & TRW 4.280" bore. $25 each.
*MANTON 3/8" heavy wall pushrods for 440 with hydraulic cam and adjustable rockers. $125
*NEW Elgin 3/8" chrome moly pushrods for 383-400 with hydraulic cam. $75
*VDO 9000 RPM Play-Back tach with shift lite and instuctions. $160
*NEW Mickey Thompson 28.0 x 7.5 - 15 Sportsman front tires. pr. $240
*Weld 15 x 10 Pro-Stars. 3-1/2" back space. 5 x 4-1/2" bolt circle, Mopar & Ford,
with new Caps. pair. $300
*340 +.030" forged pistons, Full dome 12.5:1 compression. Litened and gas ported by Patterson
Racing. For .990" wrist pins. (not included) $250
*SB Mopar head stud kit $60
*NEW Hyper-Coil coil over springs 14" x 2-1/2" 300# $100 pr
*used Grinner II power glide trans-brake valve body with solenoid. $125
*Power glide Aluminum trans shield for deep pan. Good condition - SFI expired. $50
*NEW Mopar Performance 3.9 V6 Head gaskets. $10 pr
*Biondo Racing Air cylinder throttle stop/ throttle controller with air cylinder, solenoid, and CO2 tank and regulators. $125
($259 New)
*NEW 727-904 Torque-flite 5.0 Ratio band apply rocker *****$25
*NEW Mopar Performance Leaf Spring Perches. In the box. *****$15
*Barry Grant 1/2" 4-hole wood spacer for 4500 Dominator carbs. *****$20
*Used K & R Delay Box - - Early Model - - Model XTC-200 with Throttle stop, Delay & Cross-over. Works!! *****$50
*ARIAS Small Block Mopar 340 PISTONS, +.040" --4.080" Bore, 13.0 Compression, 547 grams, 1/16 x 1/16 x 3/16" rings, .400" tall dome,
With Tool Steel Lite Weight Pins, For .990" BBC pin size. Must hone rod from .984" to .990". (More pin selection available for .990 pins than
SB Mopar). 6 used with less than 100 runs on them and 2 NEW. Pistons new were over $650 and pins $200 + honing pistons for pins.
1/2 price *****$450 OBO.
*NEW Chrome Small Block Mopar Chrome Valve Covers *****$30 pair.
Thanks.
SORRY, Forgot contact info:
Can supply more pictures of interested parts, but may take 24 -48 hours. Please be patient.
Parts can be shipped by UPS or USPS at actual cost.
Cash, Money orders, Pay-Pal or ?
***ALSO LOOKING FOR 6.1 HEMI PARTS******
Are the ARIAS Small Block Mopar 340 PISTONS, +.040" --4.080" Bore, 13.0 Compression, 547 grams, 1/16 x 1/16 x 3/16" rings, .400" tall dome, Stock stroke? What is the pin height??
Ryan, Don't know how to attach a pix in this reply. Send me your email address and I'll forward them to you.
Thanks,
Tom
Pistons are for stock 340 stroke, 3.31" with 6.123" rod. Pin height/compreesion distance is 1.800" with .990" wrist pin.
If I can be of any further help, let me know!
Thanks,
Tom
W-2 Street dominator intake, Gibson headers, Weld wheels & PG tranny-brake all SOLD.
SBM head studs are Milodon. Should be $50.
Thanks
UDATE On Parts AD:
W-2 Heads, Street Dominator and rectangular port Strip Dominator intake are sold. Still have oval port Strip Dominator for W2 heads.
TCI shifter Sold.
Gibson Headers Sold.
Strange Axles Sold.
340 TRW flat tops Sold.
Weld Wheels and Trans-brake are Sold.
Arias SB Mopar pistons are also Sold.
Thanks FABO!
