[SOLD] Mopar Upper Control Arms Big Ball Joint 73 74 75 76 Duster Dart Demon Valiant
hemi71x
hemi71x
Rancho Cordova, CA
What i have here are a pair of upper control arms that are used on the 1973-76 Mopar A Body cars such as Dart, Valiant, Duster, Demon. These control arms are required to be used on 1972 and earlier A body cars when doing a disc brake conversion to the larger 4 1/2 inch bolt pattern B or E body disc brakes or the 73-76 A body disc brakes.
I cleaned them up of all the grease and grime in the solvent tank, and then soaked them off in a solution of a product called Evaporust, to remove the surface rust from these control arms. You paint them the color, and texture paint of your choice. I will leave that up to you. A very nice pair of upper control arms. One of the best pairs that i have come across. Not rust pitted pieces of junk, from the rust bucket states here in the USA. You can't go wrong with California, Nevada, Arizona parts.
The ball joints were recently replaced in these upper control arms, before it got to the wrecking yard. They are nice and tight. They DO NOT need to be replaced, so you don't have to spend any more money at the parts store, buying ball joints. Two of the bushings are still in good shape, and the other two are in so, so condition. You replace two, or all four. Your call, your determiation, upon inspection, what you want to do with them.
This set i found last week, on a 1976 Plymouth Valiant, while making my wrecking yard rounds. This pair are now the last ones that i have in stock. These 35+ year old cars are not showing up in my area anymore, and these UCA's in this condition are getting hard to find.
$165.00 for the pair, + whatever the FEDEX charges for shipping, insurance, signature delivery, to your zip code.
Contact me with a PM message through this forum. Thank's a lot
Jim V.
