BVoelzke
I tried set of the cheap fabricated covers and the gasket blew out because the cover was flat on the bottom with no lip to hold the gasket in place. I went back to my M/P cast aluminum ones that have a lip to keep the gasket in place. I machined the ribbing off and kept the Mopar PerformanceWhat is pictured is a big block valve cover.
What the description says is wrong since ALL - LA heads use the same pattern for the gaskets and valve covers.
