So, I got the frame loose and the window mechanism out. I used Gorilla Tape to help hold the window. With the use of a “pick,” removing the cat whiskers was not hard - and that’s when I discovered the old shop hands mangled the outer whisker to the point it needs replacing. Did not plan on that. More tape over painted surfaces.
Getting the window frame out of the door shell with the window is a Royal PITA. I think this whole unit was designed by a team of MENSA candidates. The frame fits tight, and the tape makes it tighter - ground the tape pretty good.
Once out, I discovered the shop hands had not lubricated anything, totally screwed up and smashed the front slide material and tried using Scotch Tape as a patch rather than replace the window setting tape.
More next post
More next post
