And their facebook reply about small block Mopars.
342 out of the box. we need those flow #'s. that would help out the small block world in a great way.Did you guys check out their flow numbers.
And TrickFlows response to the Mopar question. Thanks for nothing TrickFlow.
you are correct.They won’t sell many heads if guys have to buy offset rockers.
Nothing has changed since 1976.
Me too lolFord windsor motors have always been hurtin for some good heads.
And I bought a SB Ford!!!! last year!!!!!!!![]()
Challenges you !!! to be better!!!I had a Furd once. That was enough
What does @pittsburghracer (or others) say about the intake/exhaust flow ratio (roughly 67%)? Maybe with that much intake flow that's ok?And their facebook reply about small block Mopars.
I've always believed that in a NA engine, "ya can't eat if ya can't poop" so even though you have high pressure exhaust leaving, something in the 75% ratio ("more is better") is a good target.
To a point as long as velocity is still high more is better.What does @pittsburghracer (or others) say about the intake/exhaust flow ratio (roughly 67%)? Maybe with that much intake flow that's ok?
I'd buy them.They won’t sell many heads if guys have to buy offset rockers.
Hey Pittsburgh, what do you think of those Trickflows? The Mopar ones.I’ll add my two cents. If you remember about any of my porting posts I worry as per Darren Morgan’s suggestion to worry more about port speed than port flow. When shops give exhaust flow numbers some shops use a pipe, and some don’t. I’ve seen a pipe add 30cfm.
They can be made better, bills car ran 10.34 into a 20 mph head wind after having work done on them.I’ll never buy another set. I’ve found issues with mine which I’ve posted about, I Dont like the intake and would buy a super Victor or Victor340. With that said the TrickFlow head is a great head for those that want a 6.60 ET capible head or 10.50’s in the 1/4 with the right parts.
Yeah, I have far less experience compared to you but the 5-6 sets of trickflows I've worked including my own & on at work have needed no work to be installed on an engine but checked. The 2 speed master sets I've done were BBC and they needed some work, worst aftermarket heads I've worked on were e-street Edelbrock and Windsor they were LMAO badStill not as fast as an Edelbrock or speedmaster head with the same amount of work.
They're well sorted lightweight X heads pretty muchIf I gave a crap I’d buy a set, unscrew Trick Flows porting and put a 2.08 valve in them.
I just don’t care because it’s still based on passenger car geometry.
