moroso crank/alt. pulley
35regal
can i run these on my weekend car, i got a deal on brand new moroso crank and alt pulley. trying to free up a few horses. 340 motor . thank brian
i beleive they are both 5inch they are underdriven pulleys
If I remember correctly, the Moroso alternator pulley slows the alternator down by 50% and the crank pulley by another 20-30%. You will likely have insufficient battery charging at idle and low, cruising rpm's.
The crank pulley will also slow down the water pump, if you still have the OEM version and can line-up the belts, and cause cooling problems.
