[FOR SALE] Moser a body axles for redrilled drums
68_Fastback
Riverside, California
Will end ebay auction early if someone wants to purchase before any bids are placed.
Title says it, moser a body length axles 5x4.5 big bolt pattern for redrilled small pattern drums and brakes, with 3"studs and green bearings already installed! Wouldn't work with disc setup I went with. http://m.ebay.com/itm/262088145424 $250 + shipping. Located in riverside, Ca
so these are intended to use the stock small blot drum set up correct? stock small bolt drums drilled to 4.5 bolt pattern ofcourse....
if you want big car (stock big bolt set up) drums these axles wont work correct??
Abodyjoe you're correct. Stock big bolt drums do not work as the axle flange sits slightly closer to the housing end, causes the drums to bind on the shoes when you bolt the tires on. Daves69 yes that's the moser listing.
is it just with moser axles or are dr diffs the same, eg. you can't use stock lbp drums
It's just these specific moser axles. Moser has another axle you can use the factory lbp drums and Dr diffs axles you CAN use stock lbp drums. I actually went with his axles to replace these.
