Help needed! I have a '68 cuda 340 6 bbl. , headers,mild cam,etc. Went to run it,it cranked and died.Changed fuel filters at elec.(Holley) pump and at regulator. Cranks but won't run. Thought mech.pump might be bad,ordered one and replaced it. Still won't run. Checked spark @ no. 1 cyl.;have spark. Checked regulator,have 5 1/2 lbs. of pressure. Also shows fuel in float side level plugs. It will try to light up if starting fluid is sprayed in center carb while cranking the starter,but won't stay lit. Center carb throat looks dry when throttle blades are manually opened. Any ideas on which way to go next would be appreciated. Maybe trash in center carb?
I am about out of ideas.
Thanks
LaFlash
Thanks
LaFlash
