this is a pic of 440 in a demon . i am having issues with vibration .i have not seen a big block abody in person so im not sure what motor mounts are supposed to look like. i have to shim motor up like this because i have fenderwell headers and they were hitting body.just wanted to see if anyone sees anything wrong . oh also the bolt that holds oil pomp spring in is rubbing lightly on k frame to but there is not much meat left between hole for motor mount and notch for pump . if i wanted to grind it more .
