Have a 360 .... do the motor mounts go on the inside of ears on both sides of the engine. Installing on a 69 dart .... have the original 318 on the passenger side and a 340 one for the drivers side. Looked at the other dart i have and it has both mounts on the inside of the ear.
Also ...have one long bolt ...is that for the drivers side top ...do all nuts point to the front of the car. An finally ...does anyone have the torque specs on the lower control arm ...book says 200 in ....but i have not reached that ...the torsion bar adjusting arm has gone up and when i try to push it back down ...it recoils back up ...did not want to tighten it any more ...the adjusting bolt is loosen right off ...I would think this lever would slide up and down until u put tension on the torsion bars. Any help would be great.
