Motor Removal re Motor Mounts?
340inabbody
Arizona
When pulling a motor from the top is there a preferred way to separate the motor from the K member at the mount?
Meaning motor from the mount I believe two bolts or mount from K member I believe one bolt?
Thanks, Ron
You could also remove the metal bracket from the engine.
What I typically have done is unbolt the mount from the car.
Just the one bolt...... leave the mounts bolted to the engine when you pull it. If you have the '73 and up K frame, you'll just loosen the nut a bit and tap the bolt so the large washer on each end clears the saddles
1970 K member!
Hey guys got another question regarding pulling the motor. It’s a 340 with a 904 that’s in my 1970 Satellite. So I have a lot of room fortunately. If I am pulling the trans and motor together by myself when do I pull the trans crossmember? Because of height restrictions I need to have the front of the vehicle down on the wheels as low as possible.
Can I loosen the motor mounts then get under the car and remove the transmission crossmember and lower the tail to the ground then lower the front end to the ground and snatch it like that?
Will the assembly allow for that angle in the mounts? I have a leveler on the cherry picker.
you can leave the crossmember in. The engine/tranny will slide forward enough to get the tail of the tranny past the crossmember. You'll need to remove the bolts to the transmission mount. Use a small hydraulic jack to guide the tailshaft of the tranny over the crossmember. You can drop the crossmember down as well, many do it that way too. That's only 4 bolts as well. Either way
Will the tail shaft slam down as it’s drawn out a loosened crossmember if I don’t support it? I will need to have the front end down on the wheels when I start lifting and pulling the motor forward so I won’t have access under the trans.
Not sure that you are going to be able to do this alone. Having said that, I have never tried installing both at the same time, by myself or with someone. I see it all the time on TV, but they always have about 4 people helping and still seem to have issues. I install engines and trans separately all the time by myself. Just think it out and take your time.
my experience is it wants to stay glued to the transmission tunnel. I've never had one slammed down.
Are you saying as the trans gets withdrawn from the crossmember while hooked to the cherry picker it will stay modestly vertical id the leveler is set right?
This is what I am trying to decide. Its more of an install issue getting the two lined up and mated correctly.
th
The cherry picker is more or less centered on the engine even the leveler only moves that point back 8-10 inches and the trans sticks out far behind the engine. So I would expect the trans tail shaft to want to go down. you could put some padding on the ground under the tail shaft and lower it down on the padding with the engine slightly lifted to reduce binding on any posts of the mounts. this assumes you remove the rear trans crossmember
It will want to tilt as you lift it out of the car. I just get the motor mounts off the K-frame, then I slide the engine/tranny ahead. That's when I use one of those small 24.99 floor jacks on wheels to help the tail shaft over the crossmember. Don't need a lot of pressure or anything, just get it to clear.
I do it myself a lot of times. Nice if you have an extra set of hands. I DON'T want 4 people around... LOL. Just look and be careful. Keep wiring and exhaust out of the way, even if you need to use a bungy or zip tie. Leave the starter on, just disconnect the wires of course.
Automatics are easy, 4-speed is and can be difficult. You have pick a car height, probably up on jack stands, preferably all around . High enough for you to get under there. Square of plywood under the pan on a floor jack. Least, this is the way I do it. I too have a somewhat low ceiling, but it is about 7 1/2'. Make sure that you mark the flex plate to converter bolt orientation.
Thanks can you elaborate on the flexplate to converter alignment please?
I will probably pull just the motor given my constraints.
Flex plate only mounts to TC one way, so mark 1 hole on tc and fp and yer good.
My flex-plate is the 0 balance type for internally balanced engines and torque converters. Its a star pattern with 4 bolts.
Are you saying that rotationally it fits only one way? Ie this is why it should be marked?
the bolt holes are not perfectly square. it will only bolt one way. Just use a paint marker and mark the converter and flexplate so you will get it right the first time on assembly.
