SRT_DSTRHOLC
What is needed to make this grill work? Or Can I just bolt it right up? I will NOT get a different hood.
My mounts look close enough to call it a direct swap but I haven't bolted mine up in the center yet I knew I was gonna be fabbing the center part myself. As far as the grille to fender mounting points they should line up.Can someone at least tell me if the bolt holes line up with the original 73 duster grill? Or are the mounting locations different??
