Oklacarcollecto
Life is an experiment
The picture is deceiving. My bleeders are on the top. I have a banjo fitting that has a hard line that I have tilted up to run to the line.
Would you please post a picture? I can't vision this in my head.
Complete left spindle and all other parts excluding the ball joint installed on the right. Right on the left. Then locate longer brake hoses. There is more than one thread that gives more details in you use the search. I have seen the brake hose part number and application they are using in other threads.
If you swap spindles only the bleeder will be on the bottom of the caliper.
are there any other advantages other than "slightly" better weight distribution that would make this swap worth-while to the average joe?
x2i can't imagine the weight distribution changing in any noticeable way at all. The difference between running with half a tank of gas vs a full tank would be much greater. If you can't tell the difference in handling after you fill up, you'd never notice this. The center of gravity of the caliper isn't even moving the entire diameter of the rotor, you might be moving the caliper all of 8". Might not even be that far.
As far as other advantages, the biggest one that i can think of is clearance for the front sway bar on the pre-'73 cars, the '73+ calipers tend to interfere with the end links. But that's only if you keep the pre-'73 k member and sway bar.
