Movin must sell
78 volare
Member
michigan
Rating - 0%
0   0   0
I have here a 1978 Plymouth Volare,Slant Six(225)this is my daily driver It has roughly under 166k
The car runs but has some problems,I'm sure it will make a wonderful car to the right person who can finish what i couldn't complete. Ill start with the beginning There was sludge in the system so i Flushed engine wit sea foam and installed a new oil pick up tube. There was a small knock so i replaced the connector rod bearings.didn't have the money to do this job the rite way so i only changed one of them so now the rest make noise. I also removed the head and installed new valve guides/and seals while i was there i installed new manifold and head gaskets.added a new alternator,starter,battery,cap rotor button and plugs and wires.The carb was original so i installed a reman holly 1barrel and inner and outer tie rods
Really need to sell looking for $$$2k but open to the best offer and if in the surrounding areas of Michigan i can drive the car to you or u can pick up will also consider parting out parts
CAN ALSO SEND MORE PICS IF NEEDED
