Cool. In terms of timing, a lot has to do with trial and error with your car, with your fuel, and in your hometown. The basic is somewhere around 15-18° initial, another 22-36° of centrifical depending on a few other things, and then vacuum if you have it, which you dont. The last part is how fast the curve is brought in. If you have street gears (numberically lower than 3.55) then you don't want to bring it on too fast. Racier gearing you usually can. A typical street curve would be having the centrifical start coming in around 1800rpm and being "all in" by 26-2800. Once the timing curve is set, go back and tweak the carb in terms of idle quality and response. It's not a fast process, but you'll get there.
