[SOLD] MP constant voltage pre-70 regulator, MP orange ECU and harness
physixx
Edison, NJ
I have for sale a used Mopar Performance constant voltage pre-1970 voltage regulator P/NP3690732.
Mopar Performance P3690732 Mopar Performance Voltage Regulators | Summit Racing
This regulator puts out a constant 13.5 volts.
I also have for sale a used Mopar Performance orange ECU P/N P4120505. This Orange Electronic Control Unit is for general high-performance use up to 6000 rpm.
Mopar Performance P4120505 Ignition Switch Connector | Autoplicity
Also included with this ECU is the MP wiring harness P/N P3690152 along with two 2-pole ballast resistors P/N 5206436. These parts will convert your points ignition to the electronic ignition setup.
All these parts were taken from a 1969 Barracuda mild bracket car that was upgraded to the MSD ignition setup along with a stronger engine. All worked perfectly before removal.
I would like to get $8.00 for the regulator and $40 for the ECU, harness and ballast resistors. Plus shipping.
Ken
Edison, NJ
