Msd location
joemoy29
NJ
where is everyone putting the msd box and coil. Is it possible to mount them under the dash or in glove box? Really trying to keep the bay clean? Pics would be great
All my ignition stuff is inside the fire wall to keep it cool
My msd coil and control box was under the dash. Control box mounted where the front speaker went. Coil still under the dash. Seems a good place for it, the coil. The AL6 failed and I mounted new one under the hood, for ease of maintenance.
I used the mounting bracket that came with it.I modified it and drilled holes in the battery holder and put flat head screws downward into the mounting bracket for the 6 al.After I did all that I got a msd ready to run and got away from using the box.It is kind of hard to explain since I did it awhile back
