Small Block
I have a 440 in my 74 duster and it runs the MSD ready run distributor and does fine but now i have another 440 in the shop with dual quads ported 906 cast heads and 2.14 valves and roller rockers and 10.5 compression and was needing a distributor but will the ready run unit work ok for this motor? If so what is the MSD part # that i will need. It will only be a street machine on spiked gas. Help if you can. Thanks guys and gals. Don't know why i go by "Small Block"
